1. Fix JP and HK.
2. MarketWatch allows to connect by XMLHTTP again. So I modify US module as well.
Waiting time is 4 seconds for each report from Marketwatch. This version can run fast.
But I am not sure whether MarketWatch will close this method again if lots of con-current users connect it and extract data frequently through 盈再表.
You can test this version then decide whether to release.
Ps. I only remove some codes about IE method in ‘收藏’ module. So you need to check what to modify accordingly due to updated method in US module.
